Hello, I am using BLE-series brushless DC motor and driver package and in motor Driver the communication port is RS-485,and I have to control DC motor through LabVIEW program. Is there any possible way to connect RS-485.
Need your help.
You can check out this thread: https://forums.ni.com/t5/LabVIEW/RS485-Interfacing-pins-in-myRIO/td-p/2916542
In short, not ready made and to use without getting your hands a little dirty and/or buying some extra electronics hardware.
Thankyou for sharing this link but I have already gone through this, if I am using full duplex ICs (i.e, SN65HVD147).
1. How to connect this IC to the Myrio?
2. If It is connected so can I use UART?
because the motor driver which i am using has RS-485 communication connector, so how to send the command through Myrio to the motor driver ?
You want to use a chip with auto direction control! https://www.ti.com/lit/an/slla574/slla574.pdf?ts=1671089759867
