RS232 Communication for Inficon Leak checker UL3000
I am attempting to replicate in LabVIEW what I previously accomplished using HyperTerminal. Despite trying various syntax for the same commands in LabVIEW, none have been successful.
Message 11 of 17
(773 Views)
In your settings for the port, you show settings for "COM3". In the LabVIEW code, it is set to "COM1".
What happens when you select COM3 on LabVIEW?
Message 12 of 17
(761 Views)
The COM3 screenshot was actually taken from another computer. This computer I am working on now has only COM1 port.
Message 13 of 17
(746 Views)
Have you been successful with HyperTerminal on the specific computer and port that you are using with LabVIEW right now?
I originally didn't mention it as a possibility, but another thing that can cause framing errors is bad hardware.  Either a bad serial adapter or a bad cable.  It's rare but not unheard of.  If you only got HyperTerminal to work on a different set of hardware, then it remains a possibility that you're using all the correct settings but instead you have bad hardware.
Message 14 of 17
(732 Views)
I was using trial version of Hyperterminal program and it expired after 24 hours. Now I can't communicate with the UL3000 at all. With Labview, I can communicate with other rs232 devices using the same computer and the same cable.
Message 15 of 17
(697 Views)
Hi rosh,
There is also free terminal software available. No need to use a software with a 24h trial period…
Message 16 of 17
(692 Views)
@GerdW wrote:
Hi rosh,
I'm personally a fan of PuTTY
Message 17 of 17
(688 Views)
