RS232 Communication with Agilent 34970A
Good to see you got it working. Without seeing your porgram I am going to toss out a little advice for the 34970...
Using these instruments is a two step process.
1. Configure all the measurements you are going to take and build a "scan list"
2. "Scan" the 34970 to take measurements
Here is an example of configuring a 34970 with a 34901 MUX to take one voltage and one current measurement.
The current measurement is actually a voltage across a current shunt using scaling and actual calibrated shunt resistance values.
Here is where I "scan" the 34970 to take measurements
I also attached my Agilent Scan vi, you might find it useful as I modified the Agilent example to give more output types.
=== Engineer Ambiguously ===
Message 11 of 18
(5,582 Views)
Hi !Smiley Happy
I am also trying to communicate with the "34970A", But first I need to buy the right cable to connect to the RS232 interface (see the picture below interface number 3).
I was wondering why do you use the cable "USB to Male RS232" because the RS232 interface in the back of the "94970A" is a male so you need a cable "USB to Female RS232" ?  Or maybe do you connect it to the "Alarm Outputs" (interface number 2) ? but then it is not the right interfaces or maybe there is something I don't understand ?
Could you help me ?
Best regards
Message 12 of 18
(5,025 Views)
The 34970A uses a standard "Null Modem" cable
Preferably one with all of the hand shaking lines in place so you can use higher speeds.
While a basic cable with Rx, Tx, and ground is all you really need, that type is limited to 9600 baud using Xon/Xoff flow control at best.
A "proper" cable with handshaking can go as fast as 111520 baud using RTS/CTS flow control
Message 13 of 18
(5,016 Views)
Thank you for your reply
Ok, so it is not a straight cable, but a crossed cable, but I don't understand why "AnthonyMN" use a "USB to Male RS232" instead of "USB to Female RS232" because the "RS232" interface is a male interface so I think we need a female connector to plug it into the male connector interface ?
Thank you
Message 14 of 18
(5,004 Views)
Where did he ever day he used a USB to Male RS-232?  Though I'm sure that is what he used.
He said he used a FtF null modem cable in message 6 between the USB to RS-232  and the RS-232 of the device.
That is logical.
The instrument has a Male connector.  Doesn't it?
A USB-RS-232 adapter has a male connector.
The null modem cable between them would be Female to Female.
Everything mates!
Message 15 of 18
(4,998 Views)
thank you very much,
I saw it in message 3, but it was indeed outdated, my bad.
The only thing I need to set the serial communication is the drive from labview right? (see picture below)
Or do I need to install an other drive? from Agilent?
Message 16 of 18
(4,988 Views)
NO!
In fact do not install the HP/Agilent/Keysight (or whatever they are called now) drivers, I/O libraries, or "connection expert".
You don't need them and they can conflict with LabVIEW and cause headaches
Message 17 of 18
(4,982 Views)
Following comment saved the day for me! Thank you so much.
"What about your serial settings? I have found that when using baud rates over 9600 you have to use a proper null modem cable with all the hand shaking lines and use RTS/CTS flow control, not Xon/Xoff"
Message 18 of 18
(3,927 Views)
