RS232 NI MAX Communication with BK precision instrument
I am using 1901B from bk prevision.
On the "Programming Manual" page 11 shows how to use command set to communicate with the instrument.
I am trying to use those command from LabVIEW to control the 1901B
I can see the COM port in my NI MAX but when I give the command code it shows time out error. I checked the configuration as mentioned on the manual and all looks ok.
Also I try to user Tera Term serial port , once connected I cant see any debug message and I can't type anything in the tera term.
Can you please let me know what might be the issue.
Vikash
(4,120 Views)
Accepted by topic author VikashKumar23
You entered " [CR] " which is the manual's way of designating a carriage return.  You literally entered that which means nothing to MAX or the device.  You literally sent the brackets and the letter C and R.
In MAX, enter the command, but type "\r"  (without the quotes).  That is the way MAX and LabVIEW visually show you want to send a single carriage return byte.
(4,102 Views)
Hi Vikash,
when they talk about "[CR]" they don't mean just those 4 characters literally, but the CarriageReturn char aka CR aka 0D (in hex display) aka \r (in \-code display).
See the ASCII definitions!
(4,100 Views)
so, you mean type something like:
GETD \r
I'm having the same problem, i'm trying to communicate with a BK precision 1900b power supply,
(1,837 Views)
Hi judam,
Because you also wrote "GETD[CR]". Did you read my 5 years old comment?
(1,824 Views)
