RS232 Terminal
A easy RS232 Terminal as VI is available for downlad:
Please try it out and give me feedback. Thanks
Message 1 of 16
(8,755 Views)
Very nice interface..
but after a while, it made my PC to shut down and restart Smiley Very Happy Smiley Very Happy ...
5 stars definately for the nice vi and for sharing the code !
When i will find some time, i will try to give you some feedback for the problems
Message 2 of 16
(8,740 Views)
Really? I can't believe, that this VI shut down your PC. Look on the block diagramm. It's realy easy programmed. Nothing, what can make something bad for your PC.
Message 3 of 16
(8,729 Views)
Something overflows and causes the PC to shut down.
I had made it (the shut down), in the past, in one of my programs, in a similar case.
-The "Open Interface" works in reverse, or i misunderstand the icon?
-The autosend should really go away. The thing you trying to do, can be done by selecting the "update while typing" at the "command", and writing aditional code. (I think this was responsible for the shut down.)
-There is no way to send a carriage return.
-A very nice thought is to replace the "Answer" with a table, and paint blue the transmiteed data, and red the incoming. It needs aditional coding too.
Message Edited by Pnt on 02-22-2008 05:03 PM
Message 4 of 16
(8,720 Views)
Thank you for feedback. I will remake it and announce here about a update version.
Eugen
Message 5 of 16
(8,716 Views)
Ok, I remade my terminal, it should work now.
Message 6 of 16
(8,695 Views)
I have one question now.
How can I set the cursor position in a string control?
Thank you
Message 7 of 16
(8,684 Views)
I want to try it too but the Link dont work. please upload it again.
thanks
Message 8 of 16
(8,138 Views)
Hi Eugen,
I have already used and customized your CAN terminal for some applications. This tool is very useful and well coded, making modifications easy. Therefore I'm expecting the RS232 terminal to be another great tool and I'm quite impatient to have a look at it. Please update the link.
Many thanks
Message 9 of 16
(8,134 Views)
Thank you
Unless I'm misunderstanding your question, this can be done very easily with property nodes. See attached example.
Message 10 of 16
(8,130 Views)
