Matt,
Thank you for your answer
I did all you mentioned but unsuccessfully.
It's really weird, since even the test from NI called loopback.vi doesn't
work.
I did further test with windows hyperterminal and with a program I did
through VisualBasic, no problem.
As a matter of fact, the purpose of these tests are to widen my knowledge on
NI and I recently follow an introduction course on LabView
So, I'll ask the application engineer who gave this course about my problem.
Thanks again
Gérard
Gérard Férini
Switzerland
http://home.tiscalinet.ch/gferini
"AggieMatt" wrote in message
news:506500000005000000FF890100-1079395200000@exchange.ni.com...
Hi Gérard,
Have you checked www.ni.com/idnet to make sure NI doesn't already have
a driver for your
voltmeter?
On the block diagram of loopback.vi, there should be serial port
init.vi (or something similar). You may need to configure the baud
rate, data bits, stop bits, flow control, etc. different than the
default values.
You can also set these attributes in Measurement & Automation
Explorer. These settings MUST match those on your RS-232 enabled
instrument.
Lastly, you may want to look at the LV Instrument Driver Templates
which include a good shell for communication with RS-232 devices.
Available Here: http://www.ni.com/devzone/idnet/development.htm
Matt
