RS232 communication with cDAQ
I am about to commence a project which will require my LabVIEW application to communicate with an RS232 device.  I am planning on using an Ethernet 4-slot Compact DAQ module, but can't see a way to connect through.
Is this possible? Is there a C-Series module I can buy for RS232 comms?
Dave
Message 1 of 8
(7,562 Views)
Perhaps an NI Engineer would be more suited to answer this question, but I believe the NI 9870 should work for you.  (It is technically for cRIO, but if I recall correctly, the cDAQ uses the same sized modules so they are interchangable.  Please correct me if I am mistaken!)
EDIT:
Here seems to confirm its only compatible with the cRIO: https://www.ni.com/en/support/documentation/supplemental/08/c-series-module-and-compactdaq-compactri...
So perhaps this module is only cRIO exclusive.  Could someone with more experience or NI connections check this for me 😄
If someone helped you out, please select their post as the solution and/or give them Kudos!
Message 2 of 8
(7,555 Views)
I don't think that will work.  I believe that module requires a controller (such as the cRIO) with VISA installed on it so it can communicate.  A cDAQ doesn't have a controller.  It is a package of  "dumb" data acquisition modules.  The code for communicating with a cDAQ runs on a PC, and I don't think the VISA drivers on a PC are able to communicate "through" the compact DAQ to a serial module.
If this module was able to work with a cDAQ, I'm sure it would mention it somewhere in the specifications or manuals.
Message 3 of 8
(7,540 Views)
So you mention you have a ethernet cDAQ.  Would it then be possible to add an ethernet switch, and a Ethernet to Serial device?  I have never used one but it appears that a quick google search finds lots of modules that can take ethernet from an RJ45 and convert it to RS232 in a DB9.  Here are a few links.
http://www.perle.com/products/RS232-to-Ethernet.shtml
http://www.lantronix.com/device-networking/embedded-device-servers/xport.html
http://www.bb-elec.com/Products/Ethernet-Serial-Servers-Gateways/Ethernet-Serial-Device-Servers.aspx
http://www.digi.com/products/faceted?keywords=products/serialservers/
Message 4 of 8
(7,521 Views)
Thanks for all the responses...
It's a pity that you can't use the PC RS232 port and then pass the data through to the LabVIEW application, that would have been ideal.  I looked into the serial to ethernet converters, that could be a reasonable cost solution..
Dave
Message 5 of 8
(7,499 Views)
Hi Dave,
why can't you use the PC's RS232 port - or any cheap USB-2-RS232 thumb?
Message 6 of 8
(7,494 Views)
That would be a good solution GerdW, but I have no idea how to acheive it - I haven't really done a serial communication application before, would someone be able to point me towards a helpful white paper / tutorial / sample code for doing this?
--dave
Message 7 of 8
(7,490 Views)
Hi Dave,
start LabVIEW. Go to help menu and start the example finder. Look for those "serial read and write" example VIs…
Message 8 of 8
(7,488 Views)
