RS232 missing characters
@crossrulz wrote:
@V.Life wrote:
Only because I can send it with success from TeraTerm and maybe I have not set some parameters on Labview, if it is available.
This makes me think the serial buffer on your custom board is too small for this command. I say this because you have to type in the characters into TeraTerm. To a computer/microcontroller, this is horribly slow. But your test software is just dumping the entire command all at once.
This makes sense.
@V.Life can you enable any type of flow control for the device you are communicating with?
=== Engineer Ambiguously ===
Message 11 of 11
(158 Views)
