RS232 pin connection
Hi to all,
My question is not related with the Labview, however I will do the rest with
Labview.
I don't have enough info with the serial cables and the internal pin-to-pin
connection of a serial cable.
For example, for a given pin diagram of a connector like the following:
Pin # Signal
1 GND
2 RXD
3 TXD
4 N/A
5 GND
6 DSR
7 RTS
8 CTS
9 N/A
what should be corresponding pins on the PC? In other words, which pins
should be connected
on the device side and the PC side? I want to establish a RS232 serial
connection, however
I don't have the necessary cable.
thanks in advance.
ozan...
(3,254 Views)
Ozan ONER wrote:
> Hi to all,
> Labview.
> Pin # Signal
> 1 GND
> 2 RXD
> 3 TXD
> 4 N/A
> 5 GND
> 6 DSR
> 7 RTS
> 8 CTS
> 9 N/A
> should be connected
> connection, however
> thanks in advance.
> ozan...
Depends on what yo
u want. Probably a null modem cable
Look at http://www.arcelect.com/rs232.htm
Select the jump to 9-9 null modem and see a wiring diagram
Kevin Kent
(3,254 Views)
In order to keep things simple, which works for most instruments. Connect
the Pin2 of the device to pin 3 of the Computer Sr Port. Like wise connect
Pin 3 of the deveice to pin 2 of the comp sr port. Connect 5 with 5. Don't
worry about other connections leave them open. In most cases this may work
unless your inst has some specific connection requirements.
Best Wishes
Akeel Kizilbash
"Ozan ONER" wrote:
>Hi to all,>My question is not related with the Labview, however I will do
the rest with>Labview.>I don't have enough info with the serial cables and
the internal pin-to-pin>connection of a serial cable.>For example, for a
given pin diagram of a connector like the following:>Pin # Signal>1
GND>2 RXD>3 TXD>4
N/A>5
GND>6 DSR>7 RTS>8 CTS>9 N/A>>what
should be corresponding pins on the PC? In other words, which pins>should
be connected>on the device side and the PC side? I want to establish a RS232
serial>connection, however>I don't have the necessary cable.>>thanks in advance.>>ozan...>>
(3,254 Views)
