RS485 keller sensors communication
Hello everybody,
I am using the serial port of a cRIO-FRC II with LV2015 to acquire 2 Keller RS485 pressure sensors.
To do this I am using the keller library on Real Time, I have no problem when only one sensor is connected but when both are connected the acquisition doesn't work. I see only one sensor and not for all the time.
I can't see the other sensor in none of the address available, there is someone who knows how to solve this issue?
Thanks in advance,
Marco
Message 1 of 8
(1,458 Views)
Hi Marco,
Can you share picture of the code you have done, I am working on something similar. Thanks.
Message 2 of 8
(1,407 Views)
How did you connected your wires (RS485A & RS485B) to your cRIO port.
Message 3 of 8
(1,406 Views)
Accepted by topic author MarcoTabarrini
Hi Omar,
I finally solved the problem.
I bought a RS485 to RS232 converter (something similar to the one in the pic) and linked the two sensors in parallel. The problem I had is that I had to assign a specific ID address for each sensor before acquiring them.
For doing that I used the k114 adapter of the keller sensors with their proprietary software.
The code in the picture works.
Message 4 of 8
(1,402 Views)
Thanks Marco,
How did you assign a specific ID address for each sensor before acquiring them, and how did you connected your wires( RS485A & RS485B) into that converter!! Is that converter is usb-RS485 converter or RS232-RS485 converter.
Message 5 of 8
(1,392 Views)
Thank you Marco and sorry for distributing,
Message 6 of 8
(1,366 Views)
It's a rs485-rs232 converter. The connection of the two sensors is as in this scheme.
For the id I have used the sensor producer's software, it is called CCS30
Message 7 of 8
(1,329 Views)
Thank you Marco for your understanding. My worries are that after I connect my transducers to that converter ( RS485 - RS232 converter ) the RS232 will be connected to NI PCI-e 8431/8 board which is using RS485 communication protocol, So do you think that would work or not. This board (68 pin) is connected to NI cable that provides 8 DSUB9 interface ports and shown on the PC as (COM ports). Thank you.
Message 8 of 8
(1,283 Views)
