RT Build Specifications: Component Definition Category is unresponsive
I am using LabVIEW 2013 SP1 f2, with Real-Time 13.0.1
When I open the Properties page for a Real-Time Application build specification (to run on a cRIO-9075), and select the Component Definition category, I find that the following occurs:
 - LabVIEW becomes unresponsive, and thinks for a while. It takes approximately 20-30 seconds or so to finally show the Component Defintion page.
 - When I click on Create a component definition file (.cdf), nothing happens. As I write this, I see "Required software components", and then these are greyed out: "Software component description", and "Software version" - but there is nothing to select or change?
 - If I click on another category, it takes in the order of 20 seconds to finally show this category.
 - To close the build spec (by pressing OK), it also takes a long time (more than 60 seconds).
 - Things are fine with the build spec if I never enter the Component Definition category.
Is anyone else experiencing this?
Any help would be appreciated.
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
NI Silver Partner and Automated Production Test Specialty Premier Partner
https://wiredinsoftware.com.au
DQMH Trusted Advisor
(3,666 Views)
Accepted by topic author ChrisFarmerWIS
Hey Chris,
I believe the following patch is the fix that you are looking for.
LabVIEW Real-Time Module 2013 SP1 Application Builder Patch Details
http://digital.ni.com/public.nsf/allkb/D72B45C6905D327A86257CC800547992?OpenDocument
There's a link to download the patch at the bottom of that page.
Ryan
Ryan P.
CLA
(3,607 Views)
Awesome RyanPoPo.  I will try that.
I am now curious to know why this doesn't feature on the NI Update Service!
Christopher Farmer
(3,602 Views)
