RT Controller not booting from the hard disk
 I am using an 8176RT controller with LV8.5 RT when i am trying to boot from hard disk my monitor shows Loading Labview Real Time ...... and halts there only. But when i boot thro a floopy disk its booting properly. What might be the problem can one comment on this.
Regards
Aks
(Appreciate answers by giving KUDOS)
Hit the stars.............. sky is not the limit.
(2,834 Views)
Hi Aks,
It seems the system on your RT controller is corrupt. I've seen that too sometimes.
You can reformat the RT controller using the format floppy disk, then use MAX to copy LV RT and drivers.
Hope this helps,
Daniel
(2,832 Views)
Hello Daniel,        I tried with the floppy only to format the controller but still the problem persists.
Message Edited by AHK on 07-02-2009 07:16 AM
Regards
Aks
(2,819 Views)
That's strange. Did you really format it? I think you need to type 'yes' at some point.
After formatting it there should be no LV RT on the controller, so it can't hang at "Loading LabVIEW Real-Time..." after successful reformat.
Daniel
Message Edited by dan_u on 07-02-2009 02:35 PM
(2,813 Views)
Ya i Know its strange but its true. I have tried fromating almost 10 times. I dont know whats happening.
Regards
Aks
(2,809 Views)
Try reinstalling RT on your host system.
If that also does not work.... contact NI support in your country.
.......^___________________^
....../ '---_BOT ____________ ]
...../_==O;;;;;;;;_______.:/
.....),---.(_(____)/.....
...//____//......
..//____//......
.//____//......
(2,791 Views)
