RT Debug Causes LabView to Crash With OMUDClassLinker.cpp Error
Hey all, I recently started using some classes with our cRIO RT Controller. Since I have started using the classes, if I try to debug the software I frequently get the labview disconnected error, if I try to save or reattach to cRIO, I immediately get a LabView Crash. When I restart LabView it states there was an internal error with OMUDClassLinker.cpp.
I recently updated to Labview 9.0f3 and RIO v3.3.0 and the problems seem to occur less frequently, but I am still having them occur. Any suggestions?
Attached is the "investigate error" output
(3,364 Views)
Hi nmadura,
Can you attach a sample project to see if the issue can be reproduced?  What model cRIO controller are you using?
(3,349 Views)
