RT Engine Info - Memory usage for remote panel
The amount of memory that is displayed for RT Engine Info is decreased each time a remote panel connection is made to VI running on a FP-20XX. The first connection will take a block of memory that seems to be dependant on the complexity of the panel being displayed. Each subsequent connection will tka e less until each connection takes ~ 4k. Is each instance of a remote panel connection truly using memory from the module and thus not giving it back?
(2,940 Views)
This is an undocumented and unsupported feature because it has not been thoroughly tested. The numbers it returns can be a useful guideline for troubleshooting, but should not be viewed as 100% accurate, particularly after having run a VI, then closing it and running another.
(2,940 Views)
