RT FIFO Reference being "lost"
I've got a create RTFIFO module and a RTWRITE module. The write is inside a timed loop (5ms time on a PXI-8196 controller). However, I'm having some trouble getting data out of my FIFO. In trying to solve the problem I noticed an issue with probes and trying to observe the "reference" to the FIFO thatis passed between the VIs.
If I put a probe on the RTFIFO reference before it is in the timed loop I see a zero value. Inside the loop a see a large value that makes sense if it is interpreted as a memory address but then going through a tunnel in a conditional inside the timed loop the reference becomes zero again.
This is troubling from my perspective because I don't understand how the RTFIFO write knows "where" to write data at this point.
I've attached a picture with probes in reasonable places that should help illustrate my convoluted description.
(3,269 Views)
Actually, you aren't seeing what you think you're seeing. Notice that the two probes showing the zeros are grayed-out. This means they haven't updated since they were created. The one on the left has no structure around it so I would guess that you created the probe after execution passed that point. The right-hand probe looks like its inside a case structure, but it also hasn't updated so the case its in apparently hasn't executed, or it was also created after the execution finished.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,257 Views)
Thanks!
(3,233 Views)
