RT Memory
How can we check for the memory usage of an RT controller?
Regards
Aks
(Appreciate answers by giving KUDOS)
Hit the stars.............. sky is not the limit.
(4,810 Views)
Hi!
   What controller are you using?
   Do you refer to RAM memory or to Flash memory? (I'm used with compactFieldPoint, so I refer to that system).  Are you talking about application controlled from LabVIEW on a PC, or are you embedding the application in the target (RT module)?
   I need these informations to explain better....
   Have a nice day!
graziano
(4,806 Views)
You can check the memory usage of your RT Target with the Real-Time System Manager. If you want to do it programmatically, check out Programmatically Tracking Memory in LabVIEW Real-Time.
-JR A
(4,775 Views)
