RT PC format Hard Disk Drive
Hi Andrew,
That only works if the CD is made bootable to boot the RT OS, and for that I need some install program. Or perhaps some image that I can burn on a CD.
I tried to make an image of the USB stick created with the RT Disk utility "Create Desktop utility USB drive" and burned it to an bootable CD, but it didn't work.
It came with the message: Cannot load DOS.
Frans
Message 11 of 15
(1,171 Views)
Accepted by Franzo
Hi Frans,
Using a 3.5" to 2.5" converter you could insert the laptop hard drive to a PC with a floppy drive (if you have one somewhere, as you have noticed USB floppy drives don't work) and format it there. Then put it back to the laptop and it should run just fine.
It's not so convenient, but it should work.
Hope this helps,
Daniel
Message 12 of 15
(1,166 Views)
Thanxs Daniel that I am going to try
regards,
Frans
Message 13 of 15
(1,160 Views)
Hi Daniel
System is up and running.
Thanx
Frans van Setten
Message 14 of 15
(1,140 Views)
Hi Frans
I'm glad it works, thanks for reporting back!
Daniel
Message 15 of 15
(1,128 Views)
