RT - Project Organization - Folders - Bioreactor
See the attached.
What does the bitmap image on the folders in the bioreator project mean and how did they get there?
Message 1 of 11
(4,290 Views)
Russ,
The little camera means these are "autopopulating" folders.
As you add files to these folders, they will automatically show up in your project.
The folder properties can be changed via the right-click menu.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 2 of 11
(4,269 Views)
so what are the advantages and disadvantages of autopopulating folders?
Message 3 of 11
(4,234 Views)
Message 4 of 11
(4,211 Views)
Where is this Files page of the Project Explorer window?
Message 5 of 11
(4,200 Views)
In the Project Explorer window if you head down directly beneath the Save icons there is a tab called Files. Click on that.
Message 6 of 11
(4,195 Views)
I still don't get the benefit of auto-populating folders. Maybe you have a demonstration video?
Message 7 of 11
(4,174 Views)
If you don't see the benefit - then don't use them. If you'd find yourself in need of auto-populating folders, then you'll know where to find them, simple as that 😉
Message 8 of 11
(4,164 Views)
Maybe I should rephrase that. I don't understand the benefit of auto-populating the folders. Maybe looking at the Bioreactor example, why do you think the programmer chose to use them?
Message 9 of 11
(4,150 Views)
Auto-populating folders keep the file structure in the project synchronized with the file structure on disk. Sometimes that's desirable and sometimes it's not. My guess is that in this case that's what the programmer wanted.
Message 10 of 11
(4,143 Views)
