RT: Synchronize camera and flash
Hello. I have an image capture application in which we use a special flash. In the past, we have faced the issue of images having different luminosities, which seems to be caused by a lack of synchronization between the camera and the flash (a random delay between the firing of the flash and the photo capture). We are implementing a new version of our system this time using a compact RIO. The user interface runs on a pc but the flash and the camera are directly connected to the cRIO. I have no experience with real time systems, so I’m not sure how to achieve the synchronization. That is, we expect the image to be captured a specific amount of time after the flash was fired. What is the best way to do this? Is this what timed sequences are for? Thanks
(5,201 Views)
What kind of camera are you using? Does it have hardware trigger functionality?  Does your flash have hardware triggering too?  What kind of I/O modules do you have in your compactRIO?  The best option here will be to use a digital output signal as a hardware trigger to acquire an image and strobe the flash on the same rising/falling edge.  Many camera will also allow you to set a trigger delay in case you want to start acquisition (exposure) a short time after the trigger is actually received.
A timed loop or sequence might be able to synchronize things enough if hardware triggering is not an option.  You can learn more those structures here: https://www.ni.com/docs/en-US/bundle/labview/page/controlling-timing-in-labview-applications-real-ti...
(5,169 Views)
Thanks for the answer. The camera is just an analog camera connected through the Movimed AF1501. It does. My "flash" is not really a flash but a custom made LED lamp, controlled with the ni 9474. Those two are the only modules I have in the cRIO.
So you think the best option is using hardware triggers and not through programming?
(5,156 Views)
In almost all applications, hardware triggers are going to be better synchronized than any software trigger you could develop. Not knowing anything specific about your camera, I would agree that synchronization should be done through hardware triggering.
(5,127 Views)
