RT Target Uptime?
Is there any way to determine the uptime of a cRIO target running in scan mode?
In a related question, my target does not save the clock over reboots, nor can I seem to set it from MAX (yes, I have all the latest good stuff).  cRIO-9076.
I suppose I can just read the clock, since it resets?
(2,747 Views)
One method to do this would to take the difference of 2 - Get Date/Time String VIs within your code and pass the value back as a shared variable.
(2,727 Views)
