RT Timed Loop accelerated thanks to RT Trace Tool. Why?
Dear All,
I'm using Real-Time Trace Viewer VIs to trace the execution of my program.
I noticed very very curious thing that surprised me a lot and I can not explain why it works like that.
I got a VI that reads acceleration values from accelerometer connected to myRIO via I2C.
The acquisition task is placed inside RT Timed Loop with default parameters.
I noticed that when I run my VI without RT tracing, the iteration duration of the loop is ~30ms.
However, when I enable tracing (put Start Trace before the loop and Stop Trace and Save after), the times are even 10x faster! The same loop has duration ~3ms!
I believe that this phenomenon has an easy and silly explanation, but I haven't found it so far 🙂
I hope you can help me! Thanks in advance!
I attached the VI.
Here you can find a screenshot ('false' cases are empty, just have error wire)
Software:
LabVIEW 2014
LabVIEW RT 2014
LabVIEW FPGA 2014
I2C&SPI API v3.0.0.22 by National Instruments from VIPM
Hardware:
myRIO
Best Regards,
Mateusz
Mateusz Owczarek
Certified LabVIEW Architect
Certified TestStand Architect
(3,178 Views)
Check if there is no error on the wire when you're inside timed loop after enabling trace.
(3,137 Views)
Thanks, but there is no error. Furthermore, I can see on charts that incoming data are correct and are coming much faster when tracing is enabled.
I'm attaching demonstration video to make it clearer.
https://www.youtube.com/watch?v=2XcBAP5vI_4&feature=youtu.be
Mateusz Owczarek
(3,131 Views)
Ok, this is strange. I have no idea what's going on there :?
(3,090 Views)
