RT:Why I can't make an ftp through explorer?
Dear members,
Actually I have a problem with the browser to connect with the target.
My system is a peer to peer PC desktop.
I am able to deploy and run the application without troubles and also the data exchange via the measurement and automation explorer
works fine.
The problem is when I try to estabilish a connection via ftp or http to the target.
 I type the usual URL: ftp://160.40.10.20/NI_RT/SYSTEM/WWW/  where the IP address is the target address and ...page cannot be displayed.
I'm sure the firewall is inactive and I set the pop-up and security at the minimal level.
The Web configuration in the real time target properties is so set:
TCP/IP  box checked
In the computer acess list I wrote the IP addresses of the target and the host
Webserver active checked
Webserver Browser access  I wrote the Host  IP address
User access   I placed the Host IP
Someone has idea what I made wrong?
Bye
Principiant
Message 1 of 10
(3,999 Views)
You sure abt it?
Message 2 of 10
(3,991 Views)
try ftp just to the root.   ftp://160.40.10.10  and then browse to the folder of interest.
What ftp client are you using?   Internet explorer?  Windows explorer? other?
SteveA
CLD
FPGA/RT/PDA/TP/DSC
Message 3 of 10
(3,976 Views)
Well I'm sure of these things:
The Antivirus is deactivated
The windows firewall is deactivated
The Explorer pop up and security options are at minimal level
principiant
Message 4 of 10
(3,959 Views)
Thanks for the suggestion but I already tried ad I cannot even connect to the root.
Message 5 of 10
(3,957 Views)
Try using windows explorer instead of internet explorer.
SteveA
CLD
FPGA/RT/PDA/TP/DSC
Message 6 of 10
(3,933 Views)
Sorry for the delayed answer, I was away  the last week.
Ok I tried and all it does it switch on Internet explorer and the answer is always the same: impossible to connect to the page.
Principiant
Message 7 of 10
(3,883 Views)
Have you tried/Can you connect via the command line?
I can't use IE to access the FTP on our cRIO-9004, but I use the command line more often anyway which does work fine
Windows reference if you're rusty:
To connect:     ftp <IP>
To Upload:      put <filename>
To Download: get <filename>  - N.B. both Put and Get both work off your user directory
To quit:            bye
Message 8 of 10
(3,874 Views)
Accepted by topic author Principiant
Thanks for the suggestion but I solved the problem finally.
The fact is that I use a Peer to Peer connection but the host or better IE on the host has been configured for a LAN connection. This means anytime it searches an address he wants to go through the Gateway and since the gateway is not connected....
The solution is quite straightforward:
Starting from the tool bar of IE  follow the path Tools>>Internet Options>>Connections>>LAN Settings>>Advanced..
Then in the field Exceptions (address which do not need a proxy connection) write the target IP address or if more than one the trgets addresses separated from a semi colon and that' s it.
So said it seems easy....
Principiant
Message 9 of 10
(3,872 Views)
...at the last I completely disabled the proxy, seems it gives problems also when you have setted as exception the target in a Peer to Peer configuration
Principiant
Message 10 of 10
(3,855 Views)
