RT desktop target is inaccessible, CPU 100%
I am performing RT data acquisition where I output a digital waveform and some boolean constants on port0 and acquire data on 16 channels. In the time-critical loop I acquire data, reshape it to 1D of SGL and it goes into RT FIFO. In the non-time-critical loop I buffer it so that a 2048000 long 1D array [7.81MB] is handed over to TCP to transmit it to the host.
The problem is that each time I run the target VI the load of the two cores of RT target goes up to 100% and the RT target becomes inaccessible on network, it doesn't respond to reboot command from MAX for example. As I checked it no TCP packets are sent out from the RT target to the host [or only a very few, I am unsure].
The time-critical loop executes in every 40us with priority 100, the non-time-critical loop executes in every 4us with priority 99. The LV automatically assigns the cores to the tasks.
The non-time-critical loop runs 10x faster than the time-critical one because I think it needs more time to buffer and say if the time-critical does its acquisition in x us then the rest of the time [40 - x us] is available for the non-time-critical loop to buffer the data and to tcp it to the host.
Can somebody please suggest how to get around this problem.
Krivan
(2,540 Views)
You simply overstress your RT CPU. Have a look at your desktop RT performance monitor via the video out (VGA/DVI). If you use a multicore cpu you should see which timecritical loop goes to 100%. It's recommended to use one core per timecritical loop and you can assign them manually. Are you sure that you set a priority to a non time critical loop ???
For debug I suggest to slow down the loops and monitor the CPU load. Be aware that an untimed while loop takes 100% load by default.
Hope it helps
Christian
(2,527 Views)
