RT error 84
Hi!
I'm writing a large DAQ-program, and in one of my VIs I am converting my data into a string so I can write it to a spreadsheet in the next step. However, I get this error message:
'Error 84 occurred at Format Into String in Data2String256Hz.vi
Possible reasons(s):
LabVIEW: Too many format specifiers'
Is there an upper limit in the number inputs to the 'Format Into Data'-block, and if so, is there any way of getting round it?
I attach the VI in question. Appreciate  any answer!
Regards
Rickard
(3,751 Views)
(3,726 Views)
Accepted by topic author Rickard1
Hi Rickard,
Here is a example that make the same thing as your code, but is more compact.
Klas Andersson
(3,708 Views)
Thanks alot! It works!
Regards
Rickard
(3,652 Views)
