02-27-2026 10:21 AM
I think I am doing something stupid. I did build and deploy the Real- time target. I can only acces the RT part from the GUI when I click and run the RT Main.vi. I did not enable the "Disable RT startup app" in MAX. I did try different network cables also the USB one. Anyone a idea what might be wrong?
02-27-2026 10:33 AM
Hi You,
Did you set the RTEXE to "run on startup"?
02-27-2026 11:06 AM
Hello thanx for the reply
I did click the name below "build specifications" and did click "Run at startup" is that what you are aiming at? Or do you mean something else ?
02-27-2026 11:10 AM
Now I see in MAX the CPU load is higher, I cannot connect to the cRIO from my GUI pc though. I did check the IP and that is ok. I did ssh into the cRIO and there I can find
[eth0]
dhcpipaddr="10.51.134.21"
llipaddr="169.254.198.12"
So that should be fine right ?
02-27-2026 11:35 AM
What do you mean when you say: "I can only access the RT part from the GUI when I click and run the RT Main.vi."?
Do you expect to see a user interface in case of a built RT application?
Unless your target supports Embedded UI, you cannot have a user interface directly within your RT application.
The front panels you see when running from the development environment are only a reflection of the states of your VIs currently running on your target to help you debug your code, not an actual user interface (e.g. you cannot subscribe to UI events). If you want an actual user interface, you will have to create a desktop application that connects to your RT application over the network.
Raphaël.
03-02-2026 02:46 PM
You could try adding a 60 second wait to the very beginning of your application before any code actually runs and see if that has any effect.
If you're running from startup, the application can start executing code before the system is all initialized. As a specific examples, I know if you try to immediately open some network socket that can happen before the interface has been initialized.
