RT target reboots due to system error
Hello I get the same problem without running any VIs.
I'm simply setting up a chassis with:
pxi-8196
pxi-6031E
pxi-6723
pxi-6653
Software on the 8196:
  • DataSocket for LabVIEW Real-Time 4.2
  • Intel 8254x Ethernet Driver 1.1.1.3.0
  • LabVIEW Real-Time 7.1
  • NI-1394 External Drive Support 1.3.1.3.0
  • NI-DAQmx 7.4.0
  • NI-RIO RT 1.2.0
  • NI-Sync 1.2.0
  • NI-VISA 3.3.1
  • NI-VISA Server 3.3.1
  • NI-Watchdog 2.1.3
  • Traditional NI-DAQ 7.4.0
I can see in:
- MAX -> Remote Systems -> NI-DAQmx Devices -> pxi-6031E and pxi-6723
- MAX -> PXI System (NI PXI-8196) -> Chassis1 (PXI-1042) -> pxi-6031E, pxi-
6723 and pxi-6653
When I click on "NI-RIO Devices" from the "Remote Systems", the Remote system restarts and it says:
Reboot due to system error.
Redirecting output to log file.
How can I resolve this problem and see the 6653 as a RIO Device?
Message 11 of 14
(2,740 Views)
I believe you are going to need a newer version of NI-RIO installed (see this KB: http://digital.ni.com/public.nsf/allkb/0DE785E50024B40E862570C1006D05D5?OpenDocument). The newer driver can be found on our drivers page, the direct link is here:
http://joule.ni.com/nidu/cds/fn/p/sb/navsRel/lang/en?q=rio&x=0&y=0
-Bob
Message 12 of 14
(2,695 Views)
Hello Bob, I've installed NI-RIO 1.3, rebooted the system and I can no longer detect devices in remote systems.
Tony
Message 13 of 14
(2,681 Views)
The KB I linked previously states:
"You should be using NI-RIO 2.0 or above with your timing and sync module. Once you have installed the board, you must reboot your system for it to be recognized as an NI-RIO target. This reboot is required to refresh the RIO device list."
What do you see if you install version 2.0 or above of NI-RIO?
-Bob
Message 14 of 14
(2,584 Views)
