RTSI connnection PCI 6351 and PCI 6536
Dear all,
Here is my configuration
Dev1 =  PCIe 6536
Dev2 =  PCIe 6351
Connection with a RTSI cable between Dev1 and 2
I want to generate a pulse train with a low time of 5 microseconds and a high time of 1 millisecond with the Dev2/ctr0. I want to share this pulse train via RTSI on the port0/line0:7 of the Dev1. Could someone tell me how to proceed.
thanks by advance
regards
(2,537 Views)
Hi Mnemo15!
First of all, to synchronise your PCIe Boards together, you have to add a RTSI wire in Measurement Automation Explorer.
(See this link: http://digital.ni.com/public.nsf/allkb/A120195AAAA9222A86256C69007C8B27?OpenDocument)
Once you did that, you must create you pulse train thanks to a counter and export your pulse train over the RTSI bus.
To finish, you have just to get this pulse train over the RTSI bus in the other Board to use it.
Best regards.
(2,513 Views)
Dear Aurelien Coubin,
sorry i did not explain that i have already synchronise the 2 PCIe Boards and I know how to create the pulse train but what I do not know it is  how to get the pulse train over the RTSI bus in the other Board to use it. Do you have any example  I can use it
thanks by advance
regards
(2,507 Views)
