RUN WHEN CALLED FROM MENU
Using Labview 8. I created a menu to call other VI's to run test on circuitt boards. I want them to come up running when called. I have selected the vi's to run when called but they still do not come up running from the menu call. Am I missing something?
(2,402 Views)
Normally, you don't have to set a subVI to run when called. That is the default behavior. How exactly are you calling them? Posting the top level VI and one of the subVIs will help someone see what you are doing.
(2,396 Views)
