Radio button refnum control
Hi friends,
          I`m trying to get the value of radio button reference in a subVI connected in form of cluster. When I try to run it I`m getting an object reference error. I`ve attached the  snippet of my VI`s. Guide me in resolving it.
Regards Ganesh
Message 1 of 9
(5,427 Views)
You may get the object reference error when you pass a Null reference. Check whether you have connected the reference and passing it properly. At the place where you are getting the error you can probe the reference and check it is not equal to 0. You can always use the function "Not a Number/Path/Refnum?" to check for valid reference.
Message 2 of 9
(5,414 Views)
I hope then i`m going wrong in creating the refnum of the radio button in the sub VI. I used control refnum right click select VI server class-> Generic-> GObject-> control->cluster->radio buttons is this correct way to create the reference control in a subVI.
Message 3 of 9
(5,382 Views)
Generally the best way to create a control refnum constant is directly from the control itself. Right-click the control and create a reference, then right-click the reference and create a constant from it.
Message 4 of 9
(5,372 Views)
Hi Nanthand,
                 Yeah i`ve created the same way as you described and made into cluster. In a SubVI we need to create a Control Refnum to pass the reference from the MainVI. I created that as I discussed in my
previous post.
Message 5 of 9
(5,354 Views)
You should create the control the same way you created the constant, directly from a reference to the original control, or by taking a copy of the constant and changing it to a control.
Message 6 of 9
(5,338 Views)
This way it works, but is it correct way of programming?
Message 7 of 9
(5,325 Views)
Not really. Replace the Build Array with Bundle so you'll have a cluster instead of an array, and remove the other cluster constant input.
Message 8 of 9
(5,311 Views)
Yeah I did that as suggested at LAVA http://lavag.org/topic/17705-radio-button-refnum/ thanks for the support. Kudos for the slution & support.
Message 9 of 9
(5,278 Views)
