Ramanujan Fourier Transform
I want to implement Ramanujan Fourier transform in Labview. Does anyone in this forum has already implement it? Can anyone give some pointers. Thanks
RY
(2,508 Views)
Hi RYADAV,
Unfortunately there isn't pre-developed code for Ramanujan Fourier transform. However, you can create your own with formula node following the definitions in
H. G. Gadiyar and R. Padma, Ramanujan-Fourier Series, the Wiener-Khintchine Formula and the Distribution of Prime Pairs, Physica A 269, 503- 510 (1999).
If you come across any problem using formula node, please post your code on the forum
Yupeng J.
(2,466 Views)
