Ramp speed keithley 2410
Hello
how i can increase the ramp speed on the keithley 2410.
It's used in output voltage.
Best regards
(1,295 Views)
Hi Gael,
I guess the voltage ramping is explained in the manual of your Keithley device. Is it?
To "increase the ramp speed" you could use less samples for the same voltage range (or larger voltage steps between the samples)…
(1,272 Views)
