Ramping the signal
Thanks.
From where can I download Signal Processing VIs for labview 7.1 ??
Message 11 of 18
(1,359 Views)
I don't think you can. Version 7.1 is long obsolete and you would need to upgrade to the full version. Have you considered buying the student version?
Message 12 of 18
(1,349 Views)
How do I input sample mode in sample clock in labview 7.1 ?
Message 13 of 18
(1,338 Views)
And how do I create channel fo sample channel ??
Message 14 of 18
(1,335 Views)
You've lost me...I don't know what you're referring to. Can you be more specific....post code or screenshot.
Message 15 of 18
(1,327 Views)
In the highlighted region there is a channel and finite samples option for sample clock. How can I get that ?
Message 16 of 18
(1,324 Views)
Right click on the terminal of the subVI and pick Create Constant.
Then go the to NI website and take some tutorials on LabVIEW.
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Message 17 of 18
(1,316 Views)
I don't know what you mean by "how can I get that". Have you looked at the detailed help for this VI? It tells you everything you need to know.
Example:
sample mode specifies if the task acquires or generates samples continuously or if it acquires or generates a finite number of samples.
Continuous Samples (10123)
Acquire or generate samples until the DAQmx Stop Task VI runs.
Finite Samples (10178)
Acquire or generate a finite number of samples.
Hardware Timed Single Point (12522)
Acquire or generate samples continuously using hardware timing without a buffer. Hardware timed single point sample mode is supported only for the sample clock and change detection timing types.
samples per channel specifies the number of samples to acquire or generate for each channel in the task if sample mode is Finite Samples. If sample mode is Continuous Samples, NI-DAQmx uses this value to determine the buffer size
Message 18 of 18
(1,315 Views)
