Random Error -200559
I've created a VI which uses 4 digital outpot port to control 4 LEDs and 1 analog input port to register signal from a photodiode. The code works most of the time, but sometimes this error message pops up.
From what I observed there is no clear pattern for when this happens
Any suggestions?
(5,252 Views)
Hi kj,
well, as the error message says: don't mix digital and analog channels in one task.
And it also says: don't mix input and output channels in one task!
You need, based on your description:
- one analog input task
- one digital output task
Additionally you could use
- digital input task(s)
- analog output task(s)
(5,234 Views)
Hi
Well that also how i set up my tasks.
I have one task that handles 4 digital output port and one task that handles one analog input port.
Both tasks are executed in the same while loop, but that shouldn't be a problem.
(5,218 Views)
Hi kj,
No, it shouldn't be a problem.
But as long as you don't show your VI we cannot really comment on it…
(5,214 Views)
Hi Gerdw,
Here are the VIs where the problem accours, hopes this can help
As said before, the error only accours "randomly" and not every time I run it.
Best regards Karl-Johan
(5,179 Views)
Accepted by topic author kjschmidt
I think I found the solution to the problem. (Since the error appeared ramdonly I'm not sure, but it hasn't appear since)
Using "DAQmx Create Task.VI" and assigning them with a name before generating channels solved the problem.
(5,055 Views)
