Random pulse width generation
Hi everybody,
is there some proper way how to set some deviation to pulse generator and generate pulse train with random pulse width?
  • I know I can make it with array pattern (I would not prefer this option)
  • I was thinking about nonstop initialization of DAQmx task with different pulse width (little bit scrapy I would say
Is there more "proper" way how to do this? I need to simulate real sensor output with different length of "switch ON"
state.
Thanks a lot for some recommendations! 😉
Martin
Message 1 of 9
(6,476 Views)
What hardware do you have available? What output levels do you need? better yet what sensor are you simulating?
Message 2 of 9
(6,443 Views)
I am using PXI- 1033 and I just want digital output (5V) pulses with frequency up to 1 kHz with some deviations... So Pulse width of length 1 ms is max requirement and with some deviation up to 10%, so for example random generation of pulses with 0.9 - 1.1 ms with 10 us resolution would be nice.
Message 3 of 9
(6,420 Views)
Hi mzema,
the PXI-1033 is just a chassis, which provides 5 slots for DAQ devices.
What's inside those slots?
When you want "up to 1kHz" then you will not get "pulses of 0.9ms"…
How much "randomness" do you need?
Use a card capable of outputting digital signals at 100kHz and send a boolean waveform using DAQmxWrite…
Message 4 of 9
(6,417 Views)
PXI-6251... Sorry for that 😄 I know it is just "bus chasis" for cards... But it is early mornign here, you know...
Well, you can. It depends on duty cycle...
With randomness... I wrote "deviation up to 10% with step 10 microseconds".
I need an array first, right? Means I have to exactly define this pattern and deviation first..
I was just thinking if there is some function I do not know about... That you have some type of DAQmx task, where you do not just set pulse width, but even that deviation.... But I guess you are right and I will have to go this way...
My post was more about find out if there are different and easier ways. Would be nice to have such a function. Maybe that would be nice idea to program such a VI and share it here.
Message 5 of 9
(6,412 Views)
Hi mzema,
I don't agree!
You have functions to output data on DAQ devices (all those DAQmx functions). And you have functions to create/define/generate signals. All you need to do is to combine them as needed…
Why/how should NI embed such "randomness" into a well-defined hardware driver like DAQmx?
Which kind of "randomness" aka noise? Gaussian? Brownian? White? Pink? Any other color?
That's why I disagree with your "nice to have"…
Message 6 of 9
(6,406 Views)
I said I need random pulse width... So I think I defined my problem pretty well.. But I am getting used to this forum and the effort of exaggerated critism.
Anyway. Thank you for your input.
Message 7 of 9
(6,403 Views)
Hi mzema,
And I think you haven't defined your problem so well.
There are a lot of different kinds of "randomness"!
I don't criticize you!
I just tell you where you don't provide enough information to be able to provide good answers… 😄
Message 8 of 9
(6,396 Views)
Kudo for that!
Message 9 of 9
(6,392 Views)
