Ranger 3D
Hi!
Is there anyone else who has already developed application to Ranger 3D (used Ranger Toolkit for Labview?)
+++ In God we believe, in Trance we Trust +++
[Hungary]
Message 1 of 8
(5,312 Views)
When I tried to download from here I get "RangerToolkit 2.0 Installer.zip could not be saved, because the source file could not be read.
Try again later, or contact the server administrator"
Message 2 of 8
(5,256 Views)
Accepted by topic author D60
Dear Durnek,
Please find the following link which could be helpful in accessing/ receiving documentation for Sick Ranger 3D camera, as well as support for drivers, and integration with LabVIEW.
http://www.sick.co.uk/sickivp/0/en.html
Emil
Message 3 of 8
(5,232 Views)
Thank you very much both of you!
[Hungary]
Message 4 of 8
(5,222 Views)
Durnek,
Were you able to successfully launch a SICK Ranger Labview App? I am looking to develop an app using the Ranger but am currently having a problem reading some DLL file from the registry key.... not sure why. I am trying to run the Ranger Toolkit examples that SICK provides for Labview.
I'm using LV 2010.
-Chris
Chris Walker
Certified Labview Developer
Message 5 of 8
(5,106 Views)
I have found a solution for the problem when the Ranger Toolkit example can not find the dll path.
The SICKIVP_RangerToolkit.lvlib:CheckDllPath.vi had an invalid dll path for my System (Windows 7 64bit) and therefore should read the regestry to get the correct path but in my case the VI couldn't read the registry and therefore couldn't get the correct path.
The Solution:
Either you change the Global Variable "g_pathDll" to the correct path: "C:\Program Files (x86)\National Instruments\LabVIEW 2011\user.lib\SICKIVPLibrary\_iConLibrary\icon_c_40.dll".
Or you chanage the Security input of the  "Registry:Open key" VI to KEY_READ.
Both solutions worked for me.
Hopefully i can help someone.
Message 6 of 8
(4,814 Views)
Hey guys,
I know this is quite an old post dated back to 2012, but it seems as though you have had success in running a SICK Ranger camera using the toolkit in LabVIEW.
I currently am trying to develop an application for the Ranger E camera using the toolkit, and even developing code for a simple grab, or running an example with the toolkit gives me an error 400226: Framegrabber is empty and the wait has expired (due to timeout or external wake-up)".
Have you ever seen this before and had a workaround?
Thanks.
Kind Regards,
Hans T.
CLD
Message 7 of 8
(4,504 Views)
Dear jinfonetang,
I have noticed you have already stared new discussion about your problem. Interested users please find new topic at ICK Ranger Camera Toolkit - Cannot see Image on indicator .
Yours sincerely,
JedP
Message 8 of 8
(4,430 Views)
