Rangkaian RLC paralel
selamat siang master Labview , disini saya kebingungan dengan labview. saya membaca referensi jurnal internasional tentang Rangkaian RLC , saya mencoba membuatnya sama persis yang di jurnal tetapi hasilnya perhitungannya tidak sama dan grafiknya tidak sama hasilnya . ini saya sertakan labviewnya , mohon pencerahannya , saya baru pertama kali menggunakan labview
(3,085 Views)
Hi Fafa,
as this in an English forum you should write in English…
good afternoon Labview master, here I am confused with Labview. I read an international journal reference about the RLC series, I tried to make it exactly the same as in the journal but the calculation results were not the same and the graphs were not the same. I include this labview, please enlighten me, this is my first time using Labview
This is what your VI could look like:
When you have a problem with that "international journal reference" you should attach that, too. (Or atleast place a comment in your block diagram describing the formulas you want to implement!)
(3,057 Views)
permisi saya mau bertanya , mengapa grafik resonansi saya tidak membentuk puncaknya ya? apakah rangkaian saya tidak menunjukan frekuensi resonansi ? apakah ada yang salah dari rangkaian saya ? thanks you
(2,973 Views)
Hi Fafa,
what about that "English forum" didn't you understand?
On your VI:
I removed some unneeded code and replaced some multiplications by the square function.
When the plot doesn't show the expected result you should check your formulas…
(2,954 Views)
