Raspberry Pi & LV Community Edition - run as startup error
When I deploy a .vi to the Raspberry Pi and use "Run as startup" it returns this error:
"Unable to reboot the target. It may be offline or unresponsive"
The code runs from start-up if I reboot the Pi, and runs remotely if I run the vi on my PC. But the runtime engine isn't getting restarted in the deployment process. I followed Sam Sharps tutorial without any problems. WiFi and VNC are both working fine. www.mediamongrels.com/make-ing-with-labview-raspberry-pi-part-4-user-interfaces-with-labview-nxg-web...
Using Raspberry Pi 4 Model B, LabVIEW 2020 Community Edition.
Suggestions?
Graham
Message 1 of 1
(2,144 Views)
