Raspberry Pi
Quick question on LV for the Pi , I understand LV Home 2014 is compatable with the Pi. Is the Pi only running the LV VI and the VI must be built on a PC, or can you install an entire version of LV on the Pi and have no need for a PC at all?  Also will the USB port on the Pi support all the LV USB DAQs and run the VI with out any PC power?
Alan
(3,950 Views)
You build the application on your PC and you deploy it using LINX (3.0).
Bill
CLD
(Mid-Level minion.)
(3,909 Views)
For the Raspberry PI 3 Model B you have to install in your computer:
-LabVIEW 2014 32 bit version ( if you install the 64 bit version it doesnt work, or any other LV like 2015, 2016)
-Control Design and Simulation Module
-MathScript RT Module
-NI VISA
-VI Pakage Manager
-LINX 3.0
You cant install LB in the rasbian, all that you have to do its create a build for the PI, here its a link with a detail guide for configure your computer and your PI
http://forums.ni.com/t5/LabVIEW/Raspberry-PI-installed-uncorrectly-on-LabVIEW-2014-with-LINX-3-0/m-p...
Download the guide and check it, if you need more information we are here to help you
Good luck!
Rhico
(3,896 Views)
