Rate(Hz) as an equation in DAQ Assistant
I was trying to put my Rate in the DAQ Assistant as an equation, is there any way I can do this?
Thank you!
(2,815 Views)
Accepted by Yoohooo's
You can drag the lower edge of the DAQ assistant block to show other input terminals.  Is this what you mean?
aputman
(2,796 Views)
Thanks a lot, and yes it is.
(2,757 Views)
