Re: Angular encoder measurement using cRIO without FPGA
Hi!
I need to use cRIO 9075 for my project, But is there any possible way to create the program without the hardware cRIO 9075 by using only the software. I mean right now i dont have that hardware but can i use the software module of cRIO 9075 in my labview programming?
Surya S
(3,142 Views)
Hi suryas,
no need to hijack old and unrelated threads for your own programming problems!
Yes, you can create a project with a simulated cRIO target…
What is a "software module of cRIO 9075"?
As said before: create a project with simulated hardware…
You did the beginner tutorials for cRIO/RT programming?
Btw. in your other thread you said you already have the hardware! So what's the problem anyway?
(3,136 Views)
