Re: Basic Calculator Using LabVIEW
Can someone help me with this?? A calculator belt with LabVIEW that compute all the 4 basic operation that is equipped with memory stored and memory recalled. this calculator should have a stop button even if you stop it from the app, it should keep running unless you used the stop button. in addition, the UI of this calculator should be very beautiful.
(918 Views)
Hello, Ndiwane,
this doesn't sound like a question for help, rather like an AI- prompt. Normally you have to do your homework yourself.
How far did you come by yourself at the moment?
Where are you stuck?
Did you make yourself familiar with these LabVIEW- concepts(?):
  • use of shift registers to store program state values
  • use of event structures to handle user input (even the handling of "Window Close"- events)
  • building a user interface with different styles (like System Controls, Silver Style Controls etc.)
  • use of splitters for responsiveness of UIs
Can you answer these questions?
Greets, Dave
(887 Views)
Install LabVIEW 2026.
Drop a web browser control.
Set URL to https://www.online-calculator.com/
Done.
(788 Views)
Done.
Not fully meet the requirements (square root etc not required...):
“A calculator built with LabVIEW that computes all four basic operations and is equipped with memory storage and recall. This calculator should also have a Stop button.”
So, the keyboard might look like this:
But seriously, there have been a lot of “getting started” examples:
LabVIEW - Calculator Example
Simple Calculator using LABVIEW
A simple calculator
Anyway for the topic starter, I would recommend recreating 1:1 look and feel of a vintage calculator, like this:
Nowadays, AI can also generate beautiful button images with hover and pressed states...
(776 Views)
