Re: Can I set XonLimit and XoffLimit for serial port communication?
Hi, mhd.gar.
I´m facing the same problem you mentioned.
Any tip, please?
Tnx,
Ricardo
(4,817 Views)
Its usually easier to start a new thread rather than jump into one with no activity for 7 years
What have you tried so far?
(4,808 Views)
@RICOBRASIL wrote:
Hi, mhd.gar.
Any tip, please?
Tnx,
Ricardo
VISA "Set I/O Buffer Size" MAY help IF the hardware and the driver support it.
Ben
(4,785 Views)
I do not understand your problem, I even read the old thread and still do not understand....
Anyway I just thought I would throw this out there. In my experience using Xon/Xoff for flow control only works reliably up to 9600 baud. Anything faster and you really should be using hardware handshaking like RTS/CTS.
=== Engineer Ambiguously ===
(4,741 Views)
Yes, hardware flow control is better than software flow control.
I may have last used software flow control almost 18 years ago and that was to talk to a device designed back in the 80s.
Hardware flow control is used only when the widget I am talking to requires it.
Both have become rare as computers have gotten faster. Old devices... well there is no fixing them.
Ben
(4,738 Views)
