Re: Community with Keller gauge 33X
Hello, I want to instal on labview 2014 the library provided by the maker Keller for a pressure gauge (type 33x) they sale, to have it as a palet + sub palet. The library is here , on the form of a zip:
http://www.keller-druck.com/home_e/paprod_e/progrcode_e.asp
I see in the zip that there is a "main" palet (.mnu ) and 4 sub folders containins "sub-palets" (sub .mnu files. I have unzip the all file in the labview user lib of my computer. In labview Functions palet I see the main .mnu icone of the keller batch. But the sub- palets are empty. What I am doing wrong to install this ?
(3,112 Views)
(3,107 Views)
Hi riven,
instead of bringing 16 year old threads back to live you should just start your own thread!
And you also should ask your question in just one thread instead of several ones…
I created a new thread for you and I also moved your other post in here!
Why don't you ask Keller on supporting their software?
(3,097 Views)
Not sure if this "library" is even compatible with LV2014, will check at work, but sure thing is - it is provided by Keller, so more sence makes to ask them 🙂 or if not, just try to open the VIs one by one, if all of them are OK, and maybe recreate the .mnu s for them as stated e.g. here: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9RgSAK&l=cs-SK
Jozef Lipták
(3,070 Views)
