Re: Converting character string to array
while we doing it with strings to byte array,the output is the array with their ascii values.but,i need the same characters as output in array which are used in string.
(3,452 Views)
Hi jayaadi,
don't hijack 10 year old threads…
Please provide an example of your input string and your desired output data!
(3,446 Views)
Will this work for you?
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(3,429 Views)
connect byte array to  type cast with type as "string" in for loop with auto indexing enabled.
See attached image
(3,429 Views)
