09-14-2011 03:55 PM
Hey mike!
I had the same issue but I never used hex file, so I got a few questions : I found tons of 11, 12, and 13, do I need to change all of them? And for the 2160 Bytes (can all be 0) at the end, so far the overall size of my file is already 2437a6a, way bigger than he mentioned in the solution, so shall I still go and add them?
Attached is my corrupted file. THANKS in advance!
09-14-2011 05:05 PM
Stop creating new threads for the same question. Stick to the original: http://forums.ni.com/t5/LabVIEW/Error-has-occurred-when-listing-the-contents-of-xxx-llb-with/td-p/17...
