Re: DAQ write+read analog channels
Thank you Dan,
The device used is NI_USB 6211 and the tests will be done by another person.
So from your email I understood that is not recommended to use Hardware Timed Single Point.
 And just for my information: in your example what happened if I will try to read two adiacent analog channels (that means analog->multiple channels->single measurement)? It is possible? I'm asking because then we have a multiple point...right?
Do you think this USB device will work at 5 KHz rate?
Anyway it seems it must be used sometime even at 10 KHz.
So I still waiting for a guaranted solution!
(2,315 Views)
unintentional dup post.  see here for discussion
(2,312 Views)
