Re: DSC module and Modbus RTU
Hi RC,
I used USB-RS485 4 Port device and try to read the Process Value temperature from the temperature chiller, 50C in this example. The mfg provides the address 8992 , signed 16bit register.
Here are the return received string. Please advise why we don't see 50C return value?
(1,142 Views)
Hi tell,
Because you are doing something wrong!
You forgot to attach real code. And it seems you also forgot to follow the instructions of your device manual...
(1,113 Views)
