Re: DTR state while serial port init
So fas as I understand is it then not possible to update the software anymore and I would need a second serial (USB) connection for updates.
But with these both lines connected it might work.
Message 11 of 13
(561 Views)
@MCF_Patrick wrote:
Did you find any solution to solve the problem so far?
No, unfortunately I did not, but it might work with two serial lines as proposed, the only disadvantage there is that the Arduino still reboots when the computer boots so far as I remember.
Message 12 of 13
(560 Views)
@MCF_Patrick wrote:
Hi Michael,
I have the exactly same problem. Did you find any solution to solve the problem so far?
We tried the same way you did, but with no success so far.
Did you read the thread?  Cut the trace mentioned in post 2.  Optionally, wire in an external relay as mentioned in post 4.
Message 13 of 13
(534 Views)
