Re: Digital to analog conversion labview
Hi ykgr,
How can put in the output the values for get the correct frecuency. Because I have troubles with the timing
What kind of "troubles"?
The timing is made by your Arduino (and LINX). I guess there is a documentation for LINX functions, so you should read it…
Message 11 of 13
(750 Views)
Yes, but I can not get the correct frequency. If I insert a 100 Hz frequency I obtain 4Hz in an oscilloscope. I don't know how synchronised the samples for be read correctly
Message 12 of 13
(742 Views)
Hi ykgr,
where do you "insert a 100Hz frequency"?
There is no "frequency" in your last image of your blockdiagram!
Message 13 of 13
(732 Views)
