Re: Error 1073807339 VISA READ TIME OUT
This is WAY overcomplicated. The example that GerdW gave takes the data from the VISA read and logs it to a file. There's no reason for a queue if you're not sending it to another loop. If sending to another loop then the queue should be created prior to the loops and the queue reference wired to both loops (no local variables).
Message 11 of 14
(495 Views)
Here is my new VI. This time i used state machine pattern. Unfortunately I don't have a device to try this VI therefore I used a boolean. So I was able to see if the queue was working or not but i have no idea about the other side.
Could you please help me?
Best regards.
Message 12 of 14
(472 Views)
Based on what you supplied, I would not use a State Machine.  You can just do the action inside of the Event Structure.  But even then, you are not doing anything with the queues, so why even have them?  If you are after a Producer/Consumer, then you will want something more like this.
Message 13 of 14
(455 Views)
Thank you for your answer. I'm going to try Producer/Consumer in my VI.
Also, thanks again for the example.
Best regards.
Message 14 of 14
(451 Views)
